78 Throttle Position Screw adjustment
Bakersfield, Ca
Noob mistake but instead of turning the actual normal idle speed screw I was turning the one circled in red which I think is called the throttle positioner screw? It adjust the idle but not correctly.
Ignore the blue screw.
Going to tune it using the lean drop method but what do I do with the screw that i've been messing with?
Leave it?
Is there a stock setting/adjustment?
Downloaded a manual. So if I don't have the smog equipment installed or a functional TPS it looks like I can not worry about this screw and just remove it?
