78 odometer wheel disassembly help
Bay Area California
I’m not sure but I think after a certain year they added brass fittings on both sides so the numbers can’t be changed easily.
I think I have a broken tooth inside and I wanna disassemble to check.
I’ve found through search of threads many questions about this but no definitive answer on this?
the one I purchased has 450k mile reading - Mine is wayyy lower.
Can I yank one of the brass looking fittings down the shaft a bit? (As a poster from a long while ago mentioned off hand) or is there a technique?
I noticed another cir clip behind the thinner brass fitting which if taken off would give some room to work that one up...but that’s just a theory. Previous threads had all the number circles coming off from the black side first and the white number wheel last - but for mine I just don’t see how that’s possible unless the thicker brass fitting slides up which I doubt.
Help please..any info appreciated.
The brass fitting next to the 1/10 ring is the one I pried off to remove all the number rings. Not easy to work it off, but I got it w/o breaking it.
So the one with the cir clip in my second pic next to the white numbers...ok figured - thx ... how’d you work it up? What tool?
Pretty sure I wedged two small slotted screwdrivers between the brass fitting and circlip and s-l-o-w-l-y pried and walked it off the shaft. I'll check my photos after lunch.
Edit: sorry, no other pics that would show how I did it.
ya my plan was that I’m gunna clamp it on that one end and then do that exact thing you mentioned or else get my needle nose vice grips and get a thin towel on either side and just clamp it and work it without hurting it of course
