Now I get the picture. Your light switch works, but not as it should work.
Off - running lights - head lights.
It's works now as an on/off switch.
One day there was a problem and the PO fabricated (with a piece of harness) a solution. Probably couldn't figure out the tail lights and hooked them up until it worked. That also explains the loose wires.
So you're up for a rewire job. Keep in mind that it is possible that the headlight switch is defective and the PO had no clue about it.
Wish you luck,
Rudi
Rudi, new question on the hazard switch wiring.
Per the 2nd page of the wiring diagram (4-147) the Hazard Switch gets fused power from two sources. The Grn/Red at "Tail" and Grn/White at "Stop/Horn."
The Stop Light switch gets fused power via the Grn/White wire.
The Direction Switch gets power from, presumably, the Grn/Lt Blue wire from the Hazard Switch.
The Flasher gets power from the Grn/Lt Blue from either the Hazard or Direction Switches.
So when no turn signal or hazard switch is "on" the Brake Switch gets power from the Hazard Switch.
When Hazard or Direction Switches are on the Flasher interrupts the signal to the turn signal lights making them flash.
Am I understanding this correctly so far? I always think of electricity like plumbing, controlling how the water flows. Not very technical.
So my "new" wiring harness (I am switching from the '70 Cruiser to the '79 Cruiser) never had a hazard switch to deal with, but now I do. My fuse panel incorporates an integrated Hazard/Turn Flasher. Where the flasher plugs into the panel there are of course two female spade terminals. One has two brown wires. One brown wire feeds from the power bus bar to the "Turn Relay", to the Flasher. The wire then goes from the Flasher to the "Hazard" screw connection. The second terminal has orange wires. The first wire runs from the power bus bar to the "Flasher" Fuse and then to the Flasher. From the Flasher then to the "Turn Switch" screw connection.
Does this mean the Hazard is Fused via the Flasher?
I'm thinking I could unplug the Flasher, exposing the two female spade connections, run a wire from the "Brown/Turn Relay" connection to the Hazard Switch at Grn/Red. This connection would be two wires, the second wire returns to the "Brown" Flasher. I would then run a short wire from the Orange female terminal on the Fuse panel to the "Orange" Flasher. It seems this would give me power to the Hazard Switch first, as does the Toyota wiring diagram. Or am I all wet because I have water running everywhere
