'77 to '80 carb insulator differences
BeerM3
Wamego, KS
I've had no luck searching for the answer to this: My engine, based on the block stamp, is about a 6/79. It's de-smogged and runs well...so this might fall under 'ain't broke don't fix it' but I figure it can't hurt to ask. It came without a carb insulator.
Toyota made carb shield 21912-61030 for 09/1977-01/1979. Assuming there was an actual design change I probably need 21912-61031 for 01/1979-07/1980. Does anyone know what the physical difference is? Would it matter on a de-smogged 2f? I also don't have the stock air cleaner as you can see in the pic. Make/model of the carb is also unknown, but I suspect it's one of the non-smog Chinese versions.
1907574
WAG the older version had 2 vacumn ports on the insulator,
the newer version has 1 that sticks up at a right angle
I think the thickness is the same but not 100% sure
Well that's 100% more than I knew to look for previously, so even a WAG is appreciated!
Is that chrome thing at the back of the valve cover some sort of crankcase breather?
