Ok, I'll admit, it's been sitting for far too long. Time to get it out again and enjoy it thought I...
Last night;
Charged up the battery
Pulled the plugs and squirted a little oil in each cylinder.
Bled the clutch slave (leaks down a little - it's on the do list).
Tried to remember the secret start sequence for the 2F, at 25*C... Choke, pump, floor it crank...
Now, last time it sat like this I charged the battery and cranked and it fired right up. I guess I got lucky.
Crankity crank, nothing. No pu-puh-pop.. Nada. Got out and could smell gas, so quite possible I flooded it with the incorrect combination of the secret start sequence... Let it sit for a bit and tried a few more goes before the battery got too low and the Mosquitos got too thick.
Tonight;
Decided to check a few more of the basics before I drained the whole battery down.
Carb sight glass is half full
Fuel filter has fuel, and can see it pulsing when I crank
Pulled #1 plug, grounded it. Cranked from the starter (with ignition on) no spark.
Checked the coil voltage, 12V both sides
Checked the coil resistor, seems legit.
Grounded the (-) side of the coil, it sparks
Have 12V on the distributor feed wire
Popped the distributor cap off, everything is clean but I did a few quick passes on the rotor with a wire brush
Saw some weak spark...
Pulled the wire from the distributor and plugged directly into the coil, got a few more sparks, but still what I would consider weak.
Put the coil wire back to the distributor, and the plug wire back, put the plug back in, put the wire back on.
Cranked it over, nothing. Not even a pop.
Got the brilliant idea (I thought) to get my timing light out and see if it could pick up on the spark signals. It can, but they don't seem to be consistent. Plug wires are in great shape, distributor cap and rotor are as well - I replaced them, probably within the last 5,000 miles, though it has been a few years. Plugs are all clean and looking as I would expect them to.
Truck was driven to where it currently sits, an nothing has been removed or adjusted...
So... Where is the weak link? Is there a more definitive test for the coil? What should the resistance be? If I recall it was under 2ohms. What is the resistance of the resistor supposed to be?
I'm hoping to be swapping my 3B into the 40 so I would rather not put much, if anything ($) into getting the 2F going... Just 1000 times easier to drive it from where it is, than tug it... (And would like to take it for one last boot before surgery (if things go that way)
Oh @Pin_Head save me now, ih8sparkignition!!
Last night;
Tonight;
