For Sale 76 FJ40, V8, SOA, PS, 36" tires -Knoxville, TN $7500
Knoxville, TN
So it's time to start clearing out projects and the driveway (have had 3 separate 40 projects going this past year). I currently have a primary 40 I wheel, I don't really need a second one. It will make someone a great resto-mod 40 with some body work or a solid wheeling truck with a bit less. I purchased it back in 2013 and it has been side-lined so I would like to pass along to someone else to enjoy. A lot of new components, truck mainly needs some time and TLC to complete.
The Good
1976 FJ40 (Oct 1975)
Chevy 327 (Engine ID F0723S, block casting #3782870) - runs strong. (PO sold to me as recently rebuilt, but no paperwork to prove)
Edelbrock 750cfm 4 barrel carb
Edelbrock Performer intake manifold
GM Ram Horn exhaust manifolds (#3932465)
MSD ignition
Optima Yellow Top Battery
Kwik wiring harness
H41 4sp transmission
Stock transfer case
4.11 differential gears
FJ60 power steering conversion
Borgeson telescopic shaft (24")
Drop pitman arm
FJ80 tie rod ends
High steer kit
79+ steering knuckles
79+ birfields (axle housing slightly trimmed for larger birfs)
V6 IFS brake calipers/vented brake rotors - front axle
Ford F250 shock tower conversion (E5TZ-18183-A)
SOA - stock springs
Hard top - with ambulance doors
New windshield
Fully rebuild front axle - new seals, bearings, gaskets, etc...
New Aussie Locker in front differential (XD-21230)
Aisin hubs
36"x12.50"x16.5" Goodyear Wrangler R/T II Military OZ tires (5ea - 2 are brand new)
Warn Zeon 8 winch (brand new)
2nd set of Ambulance doors - 9/10 for condition available (not installed)
Set of soft doors - available (not installed)
Stock roll cage with cage pads - available (not installed)
Front/rear heater components - available (not installed)
Rear disc brake conversion - available (not installed)
The Bad
  1. Wiring needs to be completed. Engine runs fine, headlights work but, needs gauges, turn, hazard, rear harnesses completed - have all wiring, diagrams and stock harness as well.
  2. Needs exhaust system - currently just open manifolds (very annoying for my neighbors)
  3. Needs Shocks - no fronts or rears
  4. Needs anti-inversion shackles turned around properly (yes, they are on backwards/upside down)
  5. Needs 5th tire mounted - no spare rim
  6. Body work - rear sill, rear quarters rough (front , floor boards and cowl in good shape)- rust has been cut out. Can see rocker sills are not bad in pics, hard top has rust at bottom channels. Hood had had some rust cut out and patched.
  7. Steering wheel - horn grounds are rusted/broken. Wheel is in good shape.
  8. Front driveshaft needed. Front axle not cut and turned. Will need double cardin joint. Have stock front driveshaft for donor.
  9. No dash pad
As to pricing, I am pretty firm on $7500.
From the list above, you can see the value if you chose to part out. In full disclosure, I bought the 40 for $3900 in 2013 and have receipts for all I have invested for $5,500. So total I have tied up is $9,400 so I feel $7500 is a fair price...
Send me a PM if interested and for any additional info/pics requested. I am sure I have left some out above...
Thanks for looking.
Price dropped to $6500.
(Will pull second set of ambulance doors, soft doors, and rear disc conversions and try parting separate.)
**Will consider further price drop without new winch/mounting plate.
*Update - flipped all 4 anti-inversion shackles this weekend so they are all sitting properly now.
Feel free to PM me. Thanks.
Nik
Huge thank you to Nik for letting this project go! I'll take great care of her! Can't wait for the rig to ship down to Louisiana. First FJ40 project!
