You want at least a 16" rear shaft, it looks like you do have some room to go forward, have you had the body on to check firewall clearance? I used a 4runner front double cardan shortened as far as it could be and I am at 17". The pinion angle becomes very important with a short shaft so pay close attention to that. If you use a standard shaft make sure the pinion flange and e-brake are parallel and if you use a double cardan the pinion needs to point at the e-brake. You should bring that engine forward though if you don't have at least 16" for that rear drive shaft. You can flip the rear springs but if you don't have enough space for the driveshaft I am guessing you will have firewall clearance issues. Good luck!
