Hello all,
Any suggestions? I've got a left-rear ambulance door handle that has lost its ability to stop turning. What I mean is, you should only be able to turn this handle one way, but because the tang has worn away the stop (which on my part looks like the screw hole), the handle can turn past where it shouldn't be able to. The controller is spring loaded... and really should not turn beyond the horizontal position in the first picture.
Here are some pictures:
Where it should stop:
Here, the tang is passing the bolt hole (if you look close enough, the bolt hole is flat where it should be round, its been ground down by the tang passing by it):
Allowed to over-turn:
So, I can just live with it... or try and bend the tang out... Do any of you have a working example? What stops the spring loaded controller from going beyond horizontal? Is it the bolt hole? Is there supposed to be another piece of metal that has worn away?
Thanks for your advice!
-joe
-joe
