74 FJ 40?
Western Ky
Looking at a 74 with a 3 speed. Did they put the 2F or 1F engine in those trucks. How hard would it be to get a 5 speed for it?
Thanks
It came with an F engine and 3 speed. The 5 speeds are available if you have the $$$$$$$$$.
It should have a late F155 with new improved oiling system. Early 74 had a three speed then switched to a four speed in the US market. Putting a five speed in requires a split transfer case with either a hand brake which was not offered on split case in the US but can be located or hand brake on a 8/80 and later 40 series rear axle. There are other aftermarket options to. The transmission cover would need to be modified. If your intent is a five speed 79+ is easier. 8/80+ even easier still. 10/82+ is a bolt in with the correct parts.
It has what they call the F 1.5. It has the F displacement, but the improved oiling system. I have a 74 FJ55 (Pig) with that engine, with a 4 spd.
It is a good engine.
Are you dead set on a 5 speed? If not the H42 4 speed would be a decent upgrade. They can be had pretty cheap.
I agree the H42 is a nice upgrade. Did it in my 68 back in 94. In a 74 get a different transmission, transfer case shifter and drivelines and your set. The problem is top gear is still one to one in the three speed and four speed. While not as street friendly first gear in the H55F you gain lower first gear for off-road and a overdrive for pavement. Larger tires or 3.70:1 diff gears gain on pavement but come with higher gear off-road.
