I just purchased a 74 F engine off ebay to drop into my 71 FJ40. The po claimed that the motor only had 5,000 miles on it since new. It was from a FJ55 so I am assuming it will drop right into my 40. After pulling the head I think he was right--the motor looks like brand new--no carbon ledge and std. bore and all bolt heads look untouched. I have a few questions that you might be able to help with. Did all 1974 F engines come with 4 speed trans? The reason I am asking is because I am thinking about going to a 4 speed. The engine has a bellhousing and flywheel but I'm not sure if its from a 4 speed. If it is from a 4 speed what else will I need to purchase besides the trans and the transition gear. Should I go to the diapraghm clutch or 3 finger? Do I junk my flywheel and bellhousing and use the 4 speed? (if thats what i have) Will the clutch master/slave from my 3 speed work with the 4 speed? I think I will do a valve job? The po said something about putting in hardened valve seats--Is that a good idea? Thanks for any help in advance.
