'74 Disc brake conversion!
Boulder Creek, CA
Hey,
Awhile ago I had posted some questions about sourcing parts from a '84 60 series front axle. Well I took all the advice and unbolted the complete axle and steering linkage, along with the brake booster, master cylinder and associated proportioning valve. I finally collected all the extra bits and chunks to complete the mod.
I then took the drum knuckles and axles off the cruiser and prepared the axles, the '60 birfs were a bitch to part. With the axles prepped I took the die grinder w/carbide bit to the axle housing. I had measured the difference between the '74 and '60 birf measurements across the flats, only .070" difference, the die grinder made quick work of the .070". The rest was assembly pure and simple, quit quick and dirty. The only tricky part was fitting the '60 series steering rods, they had to be sectioned about 2", nice material about .250" thick, an easy welding project. I used the same rod ends and used the '40 tierod/relay rod end at the steering a rm end. Bolt on with the exception of the welding. When I went to bolt the '60 master cylinder up to the '40 there was a difference in the centering of the actuationg rod, about 1/4" had to be removed, with the trusty die grinder. Bolted that sucker up and bled the brakes. After a final check I took the beast out for a spin, the first time I touched the brakes ,I almost went through the windshield, unbelievable. This has to be the best mod I have ever done, all in all the total cost was about $150.00, $75.00 for the axle and about $75.00 for misc gaskets, retainers, fluid ect. Anyone who might be thinking about doing this, don't wait do it now.
eric:beer:
