'74 Backfiring through carb
My '74 stock (except for headers and Delco Dist (PO- and yes I know)) is backfiring through the carb. Had the card re-re-done by Jim C (Thanks again Jim). It starts great, idles at 600/650 RPM and pulls 17in/hg at idle. After getting carb back, I adjusted timing, point gap, and valves.
As I increase RPM's the engine seems fine but suddenly seems to bog down, RPM decreases, and then it begins to backfire. If I rev the engine it does fine but if i try to slowly increase RPM's it starts to backfire.
I have tried re-adjusting the timing (neither advancing or retarding helps) and re-adjusting the points gap.
Could this be a valve adjustment issue, bad distributor, or something else? I stopped messing around as I do not want to really mess something else by continuing to have the engine backfire.
Thanks,
Scott
Do you have Good spark at each wire? Correct firing order? Does your worn out dizzy wobble?
Sounds to me like a lean backfire. Accelerator pump compensates when you rev it, but a slow increase makes it run lean. Fuel level staying OK? Ported vacuum leak?
Or maybe you have a weak/ broken intake valve spring. I would think that would show up on a fast rev though.
Another thought is your timing advance is screwed up, but that doesn't sound right. Put a timing light on the engine and make sure it advances properly.
Definitely get timing straight (as you said you did). Could be worn/caked valves and seats. I had that a while back among other probs and when I did the head/valve job I saw the sealing surfaces were so packed with junk that sometimes they wouldn't seal all the way. Just a possible cause, among many including valve adjustment. Basically if the exhaust valve is having sealing/seating issues you will backfire through the tail pipe and vice versa for the intake and carb.
Didn't do this before carb work huh... Any other valve work recently?
1)Could try disconnecting one plug wire at a time and run it up as you would to get the backfire to isolate a possible cyl to tell you the valve condition.
2)Could try a comp test too, and compare readings through all ranges of RMP low to high, and compare with eachother. If you have lower readings at lower rpms on a particular cyl but psi increases at higher RPMs it could be valve adj or seating probs.
The first line of your post is the best hint of all: DELCO DISTRIBUTOR! Advance comes in quick and dirty and then leaves you short. You can only pick one powerband to optimize with it AND THAT"S IT!
I think Gumby's got a good thought on the lean mixture. There IS a certain level of acceleration in which there is still sufficient vacuum to hold back the power piston from engaging the power valve and where you are already getting the maximum fuel flow thru the primary jet. Without the added fuel of the power valve, in that scenario, the truck will lean out.
I would still suspect the Delco before the carb.
Thanks for ther help everyone. I will check a few things and double check my valves.
To answer a few questions:
No - it did not do this before. I did a bunch of work on the outside components of the engine and figured I would get the carb rebuit by Jim C. I put it back on and everything worked fine excpet for the idle. I decided to re-adjust the timing and adjust valves. Still had a problem with the idle so I sent the carb back to Jim because I figured I screwed something up messing around with mixtures and other adjustments.
I got the carb back and realized from some old papers I found that the Dist. needed to be set out beyond stock specs (12+deg out) in order for things to work. Did that and the truck idled like a champ. Needless to say I had not taken the truck for a ride since to be able to notice the backfire. Started it up the other day and decide to increase the RPM's and that is when I noticed the backfire.
I have wanted to replace the Dist with a stock dizzy. I want to keep the small cap and I do not mind having points. The carb was ported by Jim so I can use a vacuum advance. Any recommedations on Years to use?
I did pull plug wires last night but could not definitively isolate anything. I will check again as well.
Thanks again for the help and I will keep you posted.
Scott
The so-called NonUSA distributor with vacuum advance is what you want.
Dizzy timing still begs the question, Do you know what it was set at BEFORE you pulled it out. Hint-It might have been more than 12.
No I do not know what it was before but I can try tro get it back so that it was idling at the same RPM. The idle hung around 850RPM. I will try advancing it to see if that takes care of it. I thought I did that last night but I lost track of things I tried.
I saw "so-called NonUSA distributor with vacuum advance is what you want". What years would correlate as I understand the '74 was vacuum retarded and not advance. I could be wrong.
The 74 carb was retarded. So was the distributor. :D
I believe that pre 3/69 are the advance distributors, AKA "nonUSA".
Mark of Mark's Off Road, SOR, and I'll bet FJ40Jim can all set you up.
Update: Triple checked firing order and readjusted the valves. Both were fine. Kept advancing the timing and got it to where it will not backfire through the card but now it idles at 800-950 RPM. As I increase the RPM's everything seems OK. No bogging down. However when I let off the gas it get a very slight backfire that seems to go through the exhaust. Nothing big though.
I hate having the Delco in the motor. I want to be able to make adjustments at stock specs, instead of by feel. Anybody have a small cap vacuum advance Non-USA dist in good condition?
Thanks,
Scott
Good talkin to ya Scott. ;)
