1973 FJ40 with F Motor. Stock 2-barrel carb.
Before rebuilding the carb, the truck had trouble starting without using starter fluid and it ran OK but it was a little rough with an occasional back fire, not too bad though. It also had a minor manifold leak. I could tell that the accelerator pump plunger was bad before I did the carb rebuild and after tear down of the carb you could see the plunger was bad as the rubber sealing gasket on it was shot. After doing the rebuild I put the carb back on and it still won't start without starter fluid and it is running horrible, backfiring, dies just horrible. One thing I noticed after the rebuild is that the accelerator plunger has only about a 1/4" of movement which I believe it should be closer to an inch of movement, right? I did not replace the steel ball or the retainer of the pump when I did the rebuild. I am concerned about the pump discharge weight, ball, plug and washer that is in the chamber right next to the pump. When I remove the plug I get the movement on the accelerator pump I expect to get. Is there a way to put those pieces in wrong that would keep the accelerator pump from working correctly? Is there maybe something else I did that might have made the carb function in a way that would make the truck run like it is?
I also replaced the valve cover gasket and the manifold gasket. Is there anything I could have done in replacing those parts that would make it run like it is????
