72 windshield gasket issues
Hello,
I bought an OEM windshield for my 72 fj40. i also bought the Toyota gasket set, 1 piece gasket and the insert piece.
My issue is i cannot get the gasket to follow the curves of the windshield corners. I know it must be installed with the locking groove to the outside and the shallower slot on the windshield.
No matter how hard i try the gasket will not stay on the window around the corners..If forced it bows up and pops off the window all down the long sides.
I had help as I tried the install, one to slide the gasket and the other person holding it down.
No luck....
I have read nothing about this problem..I'm sure I am doing something wrong.
Any suggestions will be appreciated..
I would pay the guy down at the glass shop 40 bucks for his time and let him do it.
The last thing you want is to break that piece of glass, after you and 4 buddies dick with it for over an hour. ask me how I know.
Plus if the guy breaks it, he replaces it.....
I watched an old timer a t a glass shop install my windshield in about 5 minutes. With the frame laying flat on a table, he put the rubber on the frame. He then layed the glass on top and started working the rubber lip up over the glass with a plastic putty knife. After the glass was in he rolled in the key with what looked like a widow screen roller. Amazing to watch. As you, I had struggled a lot before I broke down and took it to a shop that had been there for many years. $20 but now I think I could do it myself.
yep!
I
X-1,000. I broke an oem window, Ended up going to a glass place and he cut me a piece from some flat safety glass, installed it in a half hour and I was on my way. I bought a new seal and lock strip at Northwest Cruisers in Portland OR, for 40 bucks and the window ran 150.00 installed. Can't go wrong!
1972 windshield glass woes
Hello, I just installed restored a late 1972. One of the hardest parts of the entire restoration was the windshield. I bought an OEM windshield at the Toyota dealer. Trust me, it will not fit. At least not with the one they gave me. They ordered 4 different ones that all came in the same size. They are too wide and not tall enough. Too make a long story short I had a glass guy measure and custom fit one to the Truck. My problem is the one that was in it originally was not the original and cut wrong. If you have the original and can use it as a template you will not have much of a problem. If all this is confusing contact me and I will help. Good luck with your project! By the way here are pictures of the one I just finished: http://www.fototime.com/inv/C71968C3B6AB491
In the "for what it's worth department," two friends and I installed a new windshield in my 40 last night using the Texican technique, except I used silicone spray instead of soap to lube the weatherstrip. It took us all of 30 minutes to remove the old glass and plop the new one in place. New Toyota windshield $59.65, $OR aftermarket rubber weatherstrip $36.92, Silicone $2.99, Beer $18.00, T= $117.56. It's not that tough if you really slime up the rubber before insertion.
Lee :beer:
Did you try the cotton rope trick? I did one of my amby door windows, and I have no doubt that I could do the windshield.
Courtesy of Texican (I used less soap than he did):
http://www.ih8mud.com/tech/glassinstall2.php
fwiw - They only have the late model 40 winshields now which is why it was oversize from toyota dealer
2X on this. Ordered one from toyota and got a late model windshield. The dealer ordered another and it was the same thing. Had the part number of the early windshield but was an inch too wide and not tall enough. Take the glass without the gasket and hold it up in the opening and you'll see it dosn't match.
If you have the old glass take it to a glass shop and have one cut out of safety glass. You won't have the tint on the top but it will fit.
Mine was $75 and that was high from what I've heard.
Kevin
Tint !?!
what tint?????? there's supposed to be tint?????
:D seriously.... I've never seen a windshield with a tinted upper
I did my 74 windshield myself....with no help....while the frame was still on the 40....
1/4" rope trick works! I used excessive amounts of windex. Put the rubber in the frame, rope in the rubber, then installed the windshield from the front (hood side).
get one corner started and carefully pull the rope out which pulls the rubber flap over the windshield. took 10 minutes maybe???
the darn locking bead took me about 30 minutes as I didn't have the handy dandy roller thingy..... go find one of those if you're gonna do it yourself!!!
Did it hold
Tint !?!
Did the window stay in when it landed on your face after it broke off?
YES!!!!!
I was wondering if someone would catch that part :D
missed my face actually.....by like 2" at the most! :eek:
It spiderwebed real good where it hit the steering wheel but stayed firmly together for both the hr-15 home AND the removal!
It's actually leaning against the garage in one piece right now:
well, turns out the OEM windshield from Toyota was too wide. So they cut me a new one and installed it at about the cost of the windshield alone.
