For Sale 72 FJ40 Project AZ
Scottsdale, AZ
Located in Scottsdale Arizona. Asking $20,000
Bad times have hit the kingdom so I need to sell my project.
Pros: full frame off resto, freeborn red, rino lined black inside, hell for stout leveler spring lift, gauges, knobs, steering wheel, windshield wiper, seats all restored, New OCD black soft top, new real steel bows painted black, later model rollbar installed, front disc brakes from a 60 refurbished and installed, rebuilt( by man a fre ) 3fe with all new sensors injectors etc with about 4000 miles on since rebuild, all new tie rod ends installed, 4 speed transmission with re-built 3 speed transfer case installed, harness wiring all inspected rewrapped and repaired before installing, all new light fixtures and all work, new agm battery, 5 new imported 16' split rims with new Hercules bias ply's installed, 3 hard doors that need work but little rust, Long rear seats that need resoration, curisreparts 3fe conversion harness all installed with relays, original 3fe engine harness all installed, in the process of installing charcoal canister on frame, 4 speed transfer linkage is being cleaned up and restored, new clutch, re-built brake booster, new fuel tank.
Cons: PO did use some bondo on the rear quarters but no sign of rust under the bondo - I think they just wanted to make it all nice and smooth. The few holes that I drilled to install the rear barn doors yielded no rust. Barn doors are lined up about a 1/4 inch off at the top - I have tried to fix but can't- I think again that the PO installed a new rear seal incorrectly which affected the barn doors and also the spare tire latch. Some minor scratches that occurred during install of parts.
It needs brake master, clutch master and slave, clutch fork and bearing installed brake lines and fuel lines, fuel pump and pre-pump filter, lines for fuel separator and fuel return installed on the fuel tank, drive lines shorted and lengthened and radiator and fan shroud installed to get running. It's real close to being running and a great rig.
I'm desperate so make me an offer!! I figure I've got over 30k just in parts alone installed.
I've got more photos of the restoration etc if you want. A ton of parts come with this. Call me if you have questions: 480-695-6744
Curt
