72 fj 40 shakle setup
Red Deer ,AB,Canada
Website
www.cardomain.com
Just installed these inversion shakles and new spring mounts on the front of the 72 FJ, looking for some feedback on the instal or if anyone sees something screwed up with the setup.
Hopin to put 36 's under it, SOA and treraflex revolver shakles for the rear with original mounts, also i should mention that the springs are flipped 180 both front and back. Going to tack on the perches for the rear, wondering if 22 degrees is the proper angle or should we just line the driveshaft up the with pumpkin. Hoping to weld everything in by the end of the weekend so that i can mesure up for drive shafts.
Thanks in advance.
just flip the shackle over... it is not an equilateral triangle...
about the pinion angle- get a CV shaft and point the pinion at the tcase rear output. Otherwhise you want the face of the pinion flange to be parallel to the face of the pinion rear output.
There is no need to run those anti inversion shackles with the bushing through the frame like you are running. Also I would not run revolvers on the rear with a soa, they open up under acceleration, or climbing objects. If you wheel hard and don't run some type of anti wrap, expect more broken pinions.
Thats my.02
rear axle
Here's a pic of the front axle with the inversion shakles setup properly ( we think ) and a couple of the rear axle setup with the new perches tack on at what we think is the proper angle. From what I've read I think we've set it up porperly with the pinion flange pointing directly to the transfercase,( because a straitght drive shaft will be used and not a CV shaft) but the angle of the perches seems to be a little out since we flipped the springs.
Again looking for some feedback on the setup and wondering if I'm going to get axle rap outta that rear axle with the perches like that.
from my understanding if you rotate the axle up to the tcase with no cv, you will end up with vibration on the rear drive shaft. unless you're using a cv, you must make sure both input and output of the drive shaft will need to be at the same angle. that said, you will not change your tcase angle. so, you can not point your rear axle up to the tcase unless you run a cv.
more here: https://forum.ih8mud.com/showthread.php?t=53925&highlight=driveline
mike
sine80 is correct. you will have vibration with no cv joint. for the front for low speed running, some have said it's not a problem, but i wouldn't do it.
in addition, if you're flipping your springs for more wb front and rear, you're going to need to have your ds retubed anyway. Might as well have a cv welded to the front and rear while you're at the drive shaft shop. i found to cv's drive shafts (mini) locally and the guy wanted $25 for each.
:beer:
Yes , Sine80 I was thinking that since I needed to extend both DS I will put CV's front and back. Can i use those DS or just take the CV's and have them welded to the FJ DS . I might try to go to a pick your part this weekend to get the CV's is there anything else I can salvage from the 79 to 85 trucks. Thank you guys for all the info. Here Is a some new Pictures of the FJ finally sitting
you can salvage everything knuckles out for a disk brake conversion if you dont already have front disks. I think this is about the best thing Ive done to my cruiser aside from power steering.
I took my front shaft and had the mini CV welded on the t-case end and used this for my rear shaft since the front is longer and rear is shorter. that way since you changed extended the wheelbase, you need a longer shaft as a core for the rear.
I got lucky and knew someone with a few spare FJ55 shafts that I used for my front. same pattern on the 3rd member ened, then welded a mini cv to the t-case end. you can check out my buildup in my sig line. I drove my truck for the first time in like 8 months this afternoon. I took it up to about 50mph and no vibration from the CV as of yet. if either were to have vib issues, it seems like the rear would becuase the shaft is shorter hence a steeper angle on the cv.
so the only thing I did to the rear shaft, (my old front shaft) was have them cut the tube to the correct legnth and mate the CV to my existing shaft. this ened up being $75 including going thru the CV and ujoint to make sure everthing was in order and they were in good working condition. they also fully removed all the old greese, reconditioned, and painted the shaft. I did a long slip in the front, plus the retub to legnth of the 55 shaft, plus going thru the shaft, plus the CV and they changed me about $250. all in all it was a good investment and im glad i went this route. plus, if you ever do something else to your rig like change the WB even more, you still should be able to use the long slip later as its like a PTO shaft from a tractor.
mike
edit: your rig looks good BTW, keep going! You've got the hard stuff out of the way.
