72 and 73 carb same?
Northern Colorado
are 72 and 73 carb same?
I currently have a Weber carb on my 73fj40 f engine, i am wanting to go back to a stock carb. I found a 72 carb and my question is will a carb from a 72 work ? are there any differences?
According to SOR they are different. As I recall the accelerator cable attachment is different.
Go to SOR's sight and do a little research there. Look at the carb pics and the rebuild kit dates.
There were two different carbs in 73, but both were operated by the same accel cable, which is also the same cable used on the 72. So as long as you have the cable tensioning bracket that holds the cable to the bellcrank on the 72 carb, you should be ok. If you are missing that bracket, I can get you one.
You will also need the mounting studs, carburetor insulator, air cleaner, and the throttle return spring plate.
Hope your donor engine is complete.
