I actually found a (nearly) ready to go bolt-on replacement visor for $7 at Pick-N-Pull. It's off a 2008 Dodge Avenger...
I had to remove a little extra plastic off of the back of the mounting bracket, which literally took about 2 minute each. I used a hacksaw, but a file or Dremel would work well too.
Before
After
The holes line up close enough to use the factory screws and holes. I'd recommend replacing the visor clip as well. The replacement visor is slightly wider than the OEM visor, which makes the OEM clip a little too fat to work with the new visor. You'll want to swap it out with the Dodge clip. I didn't take pics as you simply unscrew the old one and attach the new one. (Warning: I looked at a bunch of Dodge & Chrysler vehicles and broken visor clips look to be a VERY common problem.)
The new visor is angled a little too much toward the headliner, but you can tweak it downward a bit once it's attached. (You might want to place it in a vice for the tweaking process to ensure you don't break the plastic mounting bracket, but I like to live dangerously.)
I don't know what interior color options Dodge offered on the Avengers...I assume all the typical colors though. The ones I found were kind of a cream color, but close enough to tan to justify having a working sun visor. The ones I found also didn't have mirror lights, but oh well. I do know light up mirrors were an option on some Avengers and should be available if you have to have them.
Here's the end product.
Both sides took less than 15 minutes and cost $14. Let me know if I forgot anything....
Before
After
