7 pin mod question?
Fairfax, VA
Is there a advantage to doing a 7 pin mod on early series fj80, 91-92 years?
Thanks
:cheers:
No. You don't have ABS and, IIRC, the 7 pin mod also changes the shift points in the later electronically controlled trannies, but I could be hallucinating again.
The easiest thing to do is to simply unplug the connector on top of the transfer case that is at 1:00 when looking at the rear. This gives you full manual control of the CDL. Wrap some tape around the hanging connector and you're done.
I prefer the 7 pin mod myself...I dont like having unplugged items on my underside. You can tape the plug, but the recepticle is still open to the elements. Took me very little time...maybe 15 min...and its safely tucked away inside the vehicle.
Both ways work...so its your choice.
