69 fj40
i am looking at buying a 69 fj40 for 8000. it has a custom 9” lift. chevy 401 with carb and a fi kit that is not installed. auto xmsn. dana 44 front and 60 rear. atlas 2 transfer case. fiberglass 1 piece front end. 39” m/t’s. not sure about lockers. good body. custom shocks on the end of the front leafs. i think to prevent axle wrap. hard top and soft. cons. the rear axle is at a weird angle to the left. the interior is crap. little rust here and there. top heavy. needs alittle bit of the lift off. tires to big. should i make it deal?? thanks i have pics i am trying to load
C:\Documents and Settings\Angela Whitaker\Desktop\toyota\toyota 012.jpg
C:\Documents and Settings\Angela Whitaker\Desktop\toyota\toyota 016.jpg
wierd drive shaft angle to left.
C:\Documents and Settings\Angela Whitaker\Desktop\toyota\toyota 010.jpg
it runs beautiful. they just got back from rubicon 3 months ago and he said that nothing could stop it. he is getting out of the navy and a baby is on the way.
Just got the pics. I will try to post them up for you.
For the record, I still do not think it is worth the money.
Those rear diamond plates are notorious for covering BAD rust, the scab plates on the SOA look odd, and I have no idea what the kicker shock in the front is all about. I say walk away and look for a nicer one.
i AM RESIZING NOW.
for that kind of money you should be able to find one set up exactly how YOU want it. no use spending 8k then dropping more coin to de mod it. plus unless you really know what you are looking at you may find lots of things done on that cruiser the wrong way or booty fabbed later down the road. I say walk away and find the one that is set up how you want the first time.
I would say walk away, but it's your coin. For that kind of scratch, I would agree with bikininotdykin, you can find a much cleaner cruiser that you can modify to your liking, than trying to work backwards on that one. At least working forward, you can plan better on what mod affects the next step. Working backwards, you never know what one de-modification will lead to or affect.
GL:bounce: :bounce2:
Pete
