68 FJ40 engine seized ??
Have a '68 FJ40 that's been setting for the last 15 years. It was running when it was parked. Any suggections on breaking engine loose again ?? Thanks Rick
good luck:D more than likly not worth it.but here it goes.pull all of the plugs drain the oil also.start with wd40 in all the cylinder holes, let sit for 1 day ,then take marvel mystery oil pour in all cylinder holes let sit for a day.3rd day more mystery oil.while your doing all this waiting get your motor ready to turn over like buying new plugs most certain you will need to rebuild your starter or buy a new one.if thats not a option you will need a brass hammer to tap on the side at least.the gas tank will have to come off and cleaned real well,carb will be screwed,new fuel pump,filter,check your belts real good,coil,all the normall stuff.3rd day try to turn it over by hand,certain it wil not happen.it first when you try to start it unplug the coil.you do not want it to run yet.if you do get it started later change oil again and go from there.
Even if you get broke loose?? it won't be worth a s*** in the overall end results.. a dismantle is in order...
I had the same thing with my 72. Cruiser sat for 25 years and engine froze. I Put oil in all the cylinders and let it sit. Then tried to break it free by turning the crank back and forth. Engine wouldn't budge, started with a socket on the harmonic balancer nut and worked my way up to a 36" pipe wrench on the outside of the harmonic balancer. Ended up breaking my harmonic balancer and distroying my timing cover. Engine is still frozen so I ended up getting a F2 and 4 speed to replace it. Sad part is the motor ran great when it was parked 25 years ago.
Kevin
Do ALL of your turning the engine attempts with all of the plugs out. You don't need to fight compression as well as corrosion and compression won't do you any good until the engine turns freely.
whatever you pour on top to the cylinder...give it a safe 24 hours to seep through...My daughter rolled her 4-runner last year...the tow truck pulled her over onto her wheels...she went to start it and broke a push rod from the pressure of the oil trapped between cylinder and head...
