'67 40 Update
Keene, Ca.
I never planned on restoring this thing, but as with most projects they seem to get a life of their own.
Here's where I'm at:
I had originally decided to paint it myself with Hot Rod Flatz desert tan paint, but after looking at the color in person I decided to go with Dune Beige instead. I painted it in the driveway and had to wait until about 7:45 pm when the breeze died down. Only got 3 runs and a bug to deal with.
The original brake lines were replaced by a Downey kit that was designed specifically for this year. Jim was a huge help on this and the lines were individually tagged with detailed instructions. The Man A Fre brake line kit (that was included with the Safari 4" suspension kit) was incomplete and for a later model. If anyone else has bought this kit from MAF, did it come with 3 brake lines or 2? When I called MAF on this the sales rep said only 2 (a long one and a short one) came with the kit. Anyways, the fittings were wrong.
Rear line required cutting the steel line west of the fitting.
Radiator catch bottle. This is the wife's beer. I drink Johnny Walker and that bottle is a little large.
Header wrap and intake manifold sitting in place. The orange wrap on the wiring harness is something our aircraft mechanic came up with. It's used on turbine engines, adheres to itself as you wrap it and is high temp resistant. Neat stuff.
The Dash painted and mostly back together. The gray is just a standard Rustoleum color.
I still have a ton of stuff to do, but reassembly is a hell of a lot more fun than sanding and stripping.
Looks good, fireflyr! You should have painted it a fire retardant clay red. I wore enough of it in my day to really like the color. :D
Very nice work!!
Quick question...is that brake kit really only for a '67...cause I'm sure it will work in my '64. Where can I get more info.?
Very nice work!!
Not just for a 67, it works for early models: with 9mm fittings at the frame. Call Jim or pm him here. Their kit really made the brakes easy. He actually contacted me here when I had asked a question regarding brake fittings and extended lines for a lift. He was a ton of help, was easy to get ahold of on the phone and actually returned calls when I had a question. I can't say enough good about their customer service. They will actually make the lines as long as you want.
Absolutely sorry for telling you what you don't want to hear, BUT that Header wrapping should probably melt your Headers within 6 months. The pipes get so hot inside the wrapping that they literally crack open.
Damn. Thought I finally found something to dress them up a bit. Any chance of causing damage to the engine? That stuff was expensive and the fiberglass sucks to work with.
And thanks again for all the help.
Pat
and they say Americans are lazy.....
DOWNEY BRAKE INFO <---- this is a link
:wrench:
:lol::lol::lol: just a wee bit late...already contacted Jim, and just heard back...:lol::lol::lol:
BTW...not lazy, just tired...shouldn't even be on mud tonight...spent way too long a day in front of this computer for work, but I am waiting on some PM's...so another 15 minutes and I'm off.
PS. ...I owe you one :beer: for not looking it up first :)
Here's an update:
Got it running, fenders and lights installed, and color sanded the new paint.
I retorqued the head bolts and readjusted the valves last night. I'm still only pulling around 16 psi of vacuum at idle. Seems a bit low to me. I'm going to mess with the idle mixture a bit to smooth it out, but what a huge difference over the old F.
Something that was bothering me: the right side sat a full inch taller than the left; measured at the fender. When I installed the lift I tightened all the shackle bolts when it was still in the air. Last night I loosened all of the bolts, jumped up and down on the front frame rails and in the tub. Everything sits level now.
One other loose end: the side cover leaks pretty good. I removed it and tried to straighten it out so we'll see if it holds. When I had it out I also cut a new side cover out of 1/8th inch aluminum, so if the original doesn't work I'll try the new one.
New 33x9.5x15 BFGs should be here today. They'll go on the stock steel rims.
aren't those shackles upside down ?
I have no idea. Thought they were correct but with no included directions and very little adult supervision, anything is possible. If someone knows better let me know.
Pat
They're upside down
other than that, the rig's looking pretty sweet.
So the short side goes towards the top (if you look at the shackle as a triangle)? Thanks.
Pat
Did a search. Sure as sh!t they're upsidedown. Thanks again.
