67/40 temp sensor?
fort smith, arkansas
hey guys. ive got some coolant leaking from my engine, and I believe its coming from this little fitting on the drivers side of the block towards the rear, it looks like a temp sensor to me but theres no wire going to it. can anyone verify what it is for me? sorry its partially obstructed but its the thing in the middle of the damp area, obviously. thanks.
Block drain. On one hand, the fact there is coolant leaking from it means it’s not plugged up which is common problem.
thanks, ill see if I can track it down in the drawing and order one through Toyota today.
It may just be leaking at the threads, so tape/sealant should help. But that means draining the coolant, which might be a good thing to do anyhow. And that way you can see if the block drain is clear of stuff and whether a full block flush is called for.
