65 Headlight switch
NC
I have got 2 headlight switches here in my hands that i am trying to test and see which one if any i can use. I am rewiring this thing and know which wire goes where but am trying to figure what should be hot in what position. For some reason this truck came with 2 switches in it and only one light bulb worked total.:mad: :mad:
Anyway this is what i have for continuity.
Switch 1.
Position #2 has M,H,L with continuity Which is Guages, Dimmer,Tail/park/lic
Position #1 has M,P,L with continuity Which is Guages,Front park,Tail
Position #0 has nothing with continuity Which I take to be all off
Position #3 has L with continuity Which is Tail
Switch #2.
Position #1 has P,L with continuity Which is Front park,Tail
Position #3 also has nothing with continuity Which i take to be wrong
Anyone out there that can tell me if # 1 is close. I know switch # 2 is not good by looking at the above.
I guess what i need to know is if the front park should also come on with position # 2.
Also positions Start from the left and go right on the switch.
Thanks much for any help.
Number 1 sounds like what I have, Darin, but park is not on with 2, only position 1. And, there's no license light on a 65 unless you added it. :D
Thanks Dave. I figured if anyone knew it would be you.
And No i do not have a licence plate light. Heck right now i do not even have plates for this thing. Hopefully soon though.
I figured i would go thru this thing before i started hooking things up.
"Off" no continuity position is the third from the left. Maybe this will help you out:
Jim, I think that perhaps there are more than one version of the switch. Mine is not consistant with that literature.
There's no question that position 2 and not position 1 is the headlamp on position on my switch, like Darin's. The only way to get it to work the way the manuals say is to swap the wiring between the H and P terminals so they are opposite of what they are marked (ie, P goes to Headlights, H goes to Parking).
Dave, Got any pics of your dash ? Or any of our year model handy. Looked at SOR but kinda hard to tell. And i would like to get it looking halfway right, seeing as i am going as far into this thing as i have now. By the way, Got the motor broke in yesterday after i got back from my trip to the woods camping. Carb is flakey as you know what, but hopefully will be getting the stuff from Matt coming in the next few weeks.
Mine operates as the picture describes:confused: And mine is a brass tagged (as a '66) '65 and I have a license plate light, and no, I did not add it.
Those switches are almost bullet-proof, very heavy duty.
Ed
My 65 FJ45LPB the light switch is wired just like the posting by Jim. Does anybody have a picture of the license plate light and bracket for the FJ45LPB? Mine has a Confer bumper which has a place for the license in the center. Almost all the long wheel base trucks seem to have been fitted with the confer bumper of something close. Does anybody know of a source for the bumperettes for these trucks? I think they are different than the ones on the 40s.
John
John
Ed
Yup. My switch is the one that came with the truck. I messed with it a while (cause the wiring was really FUBAR as it came) and puzzled over the difference between the manuals and how mine actually worked. I don't suppose it is a critical issue in the end. :D
Wouldn't the functioning of the switch depend on how you have it wired? I mean, I doubt they made two similar switches that function differently.
Ed
John
John
John
My SWB uses the same licence light as a 40, and the same bumperettes. The LWB licence light is part of the left taillight assembly, an extra clear lens in the housing which faces down. Licence plate hung completely under the frame, very offroad un-friendly. Took mine off and threw it away when I made the new rear bumper for it last year.
Hth
Mark A.
That owner's manual shows how a RHD dash was set up, and doesn't show differences between the different FJ45 models, assuming there were some. When we've gone over this before, it is clear that there are a number of variations in the trucks people currently have. :D
For me, my hand is somewhat forced by the length of my choke and hand throttle cables. SO that's why I have mine where they are. The hand throttle will be a stretch to see if it actually works when I get the proper pedal linkage; it is short. The headlight switch is where it came on the truck, but would fit where the hand throttle is. But there's no way the hand throttle reaches the carb from the other holes.
I've got a later room light pull in the upper left hole which was plugged when I got the truck (I think that's standard, because in an LPB the room light switch is on the light itself). I plan to make that the fog light switch.
I've reversed the rod on the transfer case high/lo lever. Normally it interacts with the FWD pull, but I wanted the option to have RWD lo without engaging the FWD.
Dave ,
Next time you get a chance with your camera can you get a pic under the hood. I need one showing the entire firewall looking from like above the radiator.Just one straight on shot would help me alot on mine. I am not in a big hurry either, so no rush, just when you get a chance.
Thanks much again.
Ed
The switch terminals are clearly marked H, L, Bat, M, and P. If you know the wiring colors, you can see mine is wired with the correct light to the correct terminal, for the way my switch is marked. And it works the way I described, not the way the manuals say.
I'd be interested to know if other's switches are marked differently :confused:
krzyabncanuck said:
Dave ,
Thanks much again.
Does this show what you need? I know it cuts out the clutch master and heater blower, so if you need more I can do later. :)
Do not see pic on it. But it sounds like what i am looking for.
Opps, got it that time around.
Yes Sir, that is what i was looking for. Had to see where the shifter parts go, even though i am putting in a 4 speed i still would like to get it as stock as i can.
