64 FJ45LV for sale
1964 FJ45LV Toyota four door wagon for sale. The truck has a clear OR title and everything works in the truck. The truck is currently set up with the factory F engine, disc brake axle and four speed transmission from a later FJ40 cruiser with power brakes and dual master cylinder. The truck is sitting on 31" BF Goodrich Mud Terrain T/A Tires --tires are practically new. The truck has a Classic Air A/C and heating system installed----blows really cold and very hot when needed. The valves were adjusted less than a three months ago. The only areas showing some bondo (using a digital paint gauge) are the rear corners and some in the lower tailgate. Only known area of rust on the vehicle is on the bottom side of the piece that hold the hinges for lower tailgate (photo 0841)---can only be seen if laying on your back under the truck looking up. Otherwise the truck is extremely solid, including the floors and showing no other areas of rust. The truck was painted by the previous owner---not perfect but looks good from a couple feet away.
Currently the new parts on the LV are as follow:
-speedo cable
-complete tie rods
-grounding straps and battery cables
-clutch
-upgraded to dual master cylinder with power assist -new brake pads all around -new mechanical fuel pump -coil, spark plug wire and plugs -switched to use paper air filter not oil bath --have a few spare door latch components -Parking brake components - new exhaust and muffler
A rebuilt spare F engine also comes with truck---came with another project that I bought and I have no use for it---so goes with the truck. The F engine in the truck runs great---but just in case there is a spare.
Truck is located in Bend OR. Asking $18,000.00 or best offer. (541) 550-6300 or soncken@gmail.com
Photos: scottoncken's photosets on Flickr
That looks great.
Bump for the drool factor:cool:
Good luck with the sale!
bump for an amazing car, if I had 18k I would snatch that up in a heartbeat! Good luck on the sale.
Sale Pending---will post an update when the rig leaves for its new home.
