I’ve got a set of 55 axles and 60 axles and trying to figure out which route to go on my diesel conversion 55 so I’m looking for advice. Both fronts have some leaking so either way I go I will need to partially disassemble to clean up and replace gaskets.
What I want at the end of the day is:
Front/rear disc brakes with 3.73 gears (this will be a DD for the family so rock crawling isn’t a factor)
Parts I have on hand
55 axles- Front and rear drum w/ 4.11 gears
60 axles- Front disc, rear drum 3/ 3.73 gears
New rotors for the 60
Rear disc brackets that fit the Monte Carlo calipers (I believe these will fit either axle)
’85 Transfer Case (not sure if it’s a split case or not, what’s the difference?)
’72 Transfer Case (recently rebuilt)
Front and rear drive shafts for both sets (I doubt either will line up without modification)
E-brake set-up from the 60
Used 62 springs in good shape
55 springs are shot
What I don’t know or can’t do:
Will the 60 knuckles fit on the 55 axles
Weld the brackets for the 60 axles on the 55 frame
55 springs are shot
