60 Series Tailgate Lid “For Sale Thread”
Is that list current?
Unfortunately, yes that list is current. I just completed a design change and a new set of parts was cut today that might help to make construction faster. The parts are going to cost me considerably more, but there will be less labor on each one if it works.
I am up and running on the lids now, but just can't move fast enough keep up, let alone make much of a dent.
silvercruiser said:
Great product....can't wait to see what you can do for the 80 series. Please put me on the list...I'll save the $$$ President Bush is going to be giving me
I've got you down on the 80 list. :cheers:
Awesome build. Add me to the 60 list please. Sweet looking!!!
Glad to see you doing well with this Kevin!
Good news and bad news tonight.
The bad news is that the new prototype version that would save me fab time, just doesn't stack up strength wise against the old version. So back to that one I go, makes the 80 lid a bit tougher, and puts me back to the slow schedule again, but you guys don't really care about that.:flipoff2:
The good news is great news though, my plastic came in today and I milled it up this evening, it looks awesome.
It cuts and mills beautifully, it seems incredibly resilient, nice texture, comply impervious to the elements, it is marine grade, high density polyethylene, completely water proof and UV stable. I love it!
I also got over a brain fart today, looking at the laser cut profile with its nice clean holes, I suddenly realized that nice stainless pan head screws would be much more appropriate. It is tuff to get the flat heads sunk evenly, and hole size limitations keep the size limited to a #10 screw. If I use pan heads I can alleviate alignment issues and use up to a 1/4-20 screw instead.
On top of that, it just looks damn cool that way, and helps to protect the finish from being marred when things are slid over the gate since they will ride on the pan heads rater than the surface, I also wont have to keep burning up counter sinks, that is getting expensive...... I could go on, but here is a pic that shows some stand-in button heads to show what I am excited about.
:cheers:
Looks dead sexy!!
Do you have a link for the plastic? I wonder if it would be workable for constructing or covering a rear storage box?
That plastic door is sexy!!
Right on amigo. How much of an increase in price for the plastic?
Looks dead sexy!!
Yeah, the plastic just puts the whole thing over the top, can't believe how good it looks. I purchased it as a big sheet through my local plastic supplier, so no link, but it is basically marine grade HDPE, textured. I dont think it would be the best to construct a storage box, and it requires some precision work to get it as clean as the pic shows (crazy expensive anyway). But as a covering, it would be right at home. You typically see this stuff as very thin sheet, used as a top lamination or top panel in hollow core construction.
Not sure yet, but not too bad, I think about $25 additional. The material is WAY more expensive, but some other things are simpler, so I think it will work out to about that.
As of the work last night, I am inclined to not even offer the ply anymore, this is such a massive upgrade at a minimal price/labor increase that it is hard to justify using the ply.
But, I still need to test the new material and make sure it holds up properly. :cheers:
Kevin, do you happen to know how much soundproofing material I’ll need to line the inside of the tailgate on my 60 when I install my tailgate storage setup? (I’m so close to the top of the list, I can almost smell it!):grinpimp: Any recommendations for soundproofing suppliers?
OCHO4I Kevin, do you happen to know how much soundproofing material I’ll need to line the inside of the tailgate on my 60 when I install my tailgate storage setup? (I’m so close to the top of the list, I can almost smell it!) Any recommendations for soundproofing suppliers?
Oh man, I know, the list stalled right at your name!
Yours will be able to ship next week though.
You will need about 7.5sq' of material.
Depending on the condition of your tailgate, you may want to spend less or more on the sound deadener.
If you want the best cheap option, this works great.
You can also order it from Aubuchon online here.
I have some of the 6" rolls I can sell you at cost and ship with the tailgate. The stuff is good, sticks great, and works. But it is asphalt based and not very technically advanced. I have it because I can't justify spending 5 times as much on something to stick to rusty metal.
If you simply want the best, these guys seem to be the source of choice.
And this is a great explanation of what is the best and why.
:cheers:
More pictures!
Testing on the plastic went great, scratches dont show up as lighter plastic (some plastics even scratch white) It takes a lot of pressure to get compression dents and seems to be resistant to every chemical I can find, including lacquer thinner scrubbed into the surface!
Good weekend.
Just realized something...we go snowboarding a lot and we use the tailgate to gear up and gear down. So that means me 200#, my wife 135# and my son 80# are in some configuration sitting with all our weight on the tailgate of the 80. How do you think this access door is going to hold up to that kind of weight? And hold up to scratches from our boots and such?
Valid concern, we talked about this in the original tech thread a few times.
The new lid will be stronger than the OE tailgate (not saying much) and certainly strong enough to hold as many people as you can fit on it.
I can put the lids across two saw horses and stand on the unsupported middle, and once it is bolted into the tailgate I can drop a 33" tire on it. I severely abuse my stuff and my tailgate was bowed in prior to this mod, with that in mind I made the frame rigid enough to put the tailgate back into shape.
This is why I am continuing to make the frames out of a continuos piece of angle iron, the new prototype was plenty strong enough, but just not that strong.
:cheers:
Edit: Oh, and the ply lids show the scratches but the coating holds up well, the new plastic lids wont scratch from a pair of ski boots, you'd have to be wearing crampons to mess them up!
