60 series frame with previous repairs – looking for advice and real-world experiences...
Peru
Hey everyone, it’s me again. I’m back looking for some advice and honestly a bit of reassurance from people who’ve dealt with similar situations.
As some of you may know, a couple of months ago I bought a 1985 FJ62. I’ll give a bit more context: it has around 500,000 km on the odometer, and I’m fairly sure more than half of that was done working in an informal mine in Peru (Yanaquihua). So it has definitely lived a very hard life, often overloaded and heavily used. Let’s just say it didn’t exactly spend its days cruising to the supermarket.
Mechanically though, the engine, transmission, and differentials are all working perfectly. The issue is mainly with the frame. Even though there’s almost no visible rust, I started finding evidence of previous structural stress and repairs. The kind of discoveries you don’t really want to make when you’re already emotionally invested in the vehicle…
After buying it, I found a large square patch on the outside of the frame rail, which turned out to be related to a crack on the inside. I posted about that previously here:
Can i use my rig normally? - https://forum.ih8mud.com/threads/can-i-use-my-rig-normally.1379134/
Before
After that, I had the area properly addressed with fish plates and a weld repair to reinforce it:
After
I managed to accept that and move on, but as I kept inspecting the truck (because apparently I now enjoy mild stress and overthinking my life choices), I found another repair at the front leaf spring hanger on the driver’s side (I’ll attach photos). And now, with even more curiosity (or maybe self-inflicted anxiety at this point), I’ve also found what looks like another possible crack or repaired area around the driver's side transmission crossmember support.
Driver's sideLeaf Spring hanger
Driver's side Gearbox Crossmember
I’m pretty new to the Land Cruiser and off-road world, and while I really like this truck, my original plan was to use it for off-road travel and expedition-style trips through mountain dirt roads in my country. Nothing crazy… or at least that was the plan before I started crawling under the chassis with a flashlight.
Unfortunately, at the moment I can’t really afford a full body-off frame repair or a frame swap. On top of that, 60 Series frames are quite rare in my country, and the police here are very strict about chassis numbers being tied to the registration, so swapping frames would basically mean dealing with major legal and registration complications. So that option is pretty much off the table unless I suddenly win the lottery or discover hidden oil reserves.
So I wanted to ask:
In your experience, is it worth repairing a frame with these characteristics, and how did you go about doing it?
I’d also really appreciate hearing if any of you have gone through something similar. Seeing real experiences would honestly help me a lot and give me a better idea of how to move forward, because right now I’m somewhere between “this is fixable” and “why did I look under the truck in the first place.”
It’s surprising how much a vehicle can affect your mindset sometimes hahaha.
Thanks in advance to everyone for reading, sharing opinions, or stories from similar situations. Greetings from Peru.
P.S. I hope I didn’t bore anyone with the length of this post, and I really appreciate anyone who took the time to read all the way through. If you did, you’re probably as patient as this truck has forced me to become...
It honestly doesn't look bad. I have seen people daily drive and offroad way worse looking frames. If I was you I would just find all the issues make sure there is no more cracks by welding or fish plating and then move on and enjoy the truck.
My rig had a section of the frame cut out to fit an exhaust manifold and I as you was worried but after talking with some knowledgeable people I just patched it up and have now moved on.
Land cruisers are known for being robust, yours is no exception. Another way to look at it is that it adds to the story.
Great looking truck by the way!
I wouldn't say previous repairs are automatically bad.. My frame was rusted through in front of the rear wheels (common on 60s). I welded new metal in:
Frame is as good as new now.. Especially after I had it powder-coated and then sprayed the inside with chassis paint and cavity wax
If you have active cracks, then get them fixed. That frame looks solid for the most part. I would not be scared of it at all.
View attachment 4152930View attachment 4152933
Thank you for the reply.
Honestly, that's exactly what I needed to hear. I've probably spent too much time worrying about every repair and every mark I find on the frame.
I'm currently having the truck inspected, any cracks repaired, and some reinforcement added to the areas that concern me the most. Reading that you've seen much worse frames being driven and wheeled definitely helps put things into perspective.
I really like what you said about it being part of the truck's story. That's a different way of looking at it.
And thank you for the compliment, I really love the truck and i love your trailer, pretty sick!!
Thank you, that actually makes me feel a lot better.
One of my biggest concerns was finding previous repairs on the frame and wondering if that automatically meant the truck was compromised. Hearing from someone who repaired a rusted frame section and successfully brought it back gives me a lot more confidence.
Fortunately, rust is not really the issue with my truck. Most of my concerns are related to an old repair on a leaf spring hanger and a couple of areas that I wanted to inspect more closely. I'm currently having the frame inspected and reinforced where necessary.
I really appreciate your perspective. Thank you for sharing your experience.
Thank you.
That is reassuring to hear because one of my biggest fears was that I was looking at a frame that was beyond saving. I'm having the truck checked and any active cracks repaired, but it's good to hear from someone with experience that the frame looks solid overall.
I really appreciate you taking the time to comment.
