60 series diff in 40 series??
Wu guys just wondering if anyone has or no of someone go has tried to put
A 60 series diff in a 40 series cruiser?? How would you do it?
I just finishes my last night, it was easy the only learning curve was how to get the axles out then it was a straight bolt up. The only mod was I had to match drill the drive shaft bolt pattern because the 40 is a bit smaller. I just clamped the drive shaft to it and re drilled new holes. 2 hrs to remove 1.5 to replace. Now I have to do the front. Only gained 500 rpm lower from a 4.10 to a 3.73 tho. I was hoping for a little more.
The flange is removable but the spline pattern is course on the 40 and fine spline on the 60 so they won't fit. I kept all the same bolts it fit right up. I found mine on eBay for 160 shipped to my house. I am unsure of the year on the 60 diff I used.
Check out Cruiser Outfitters selection of Toyota coarse and fine spline companion flanges. If they don't have it, you don't need it.
it can be done my hj45 has been converted was done before i brought it looks like it was not hard to do check the tech pages there is plenty of help on here
Hi, looking for photos or information on the diff housing of a 60 series to mount into my HJ45.can you help at all.
Cheers
