60 series alternator same connections?
38.0111,-109.9181
Website
www.alamosa.fm
Does a 60 series alternator (other than the fact it's internally regulated) have the same connectors as the old externally regulated alternators? Is it plug-and-play (minus the voltage reg)?
The 3FE alternator I have is quite a different connector but have no 60 series to examine to find out. Thanks,
no it is not.
You need to look at a 60 series wiring diagram and see what the two smaller wires are that plug in to the alternator. Most likely an IGN +12v and a ground. I would not run the output post to the same wire as the stock 40 series one, which goes into the cab and then to the battery. The 60 series alt puts out more amperage than is safe with the wiring or ammeter. I would run it straight to the battery and then either convert the ammeter to an external shunt type or run a voltmeter.
