- Thread starter
- #21
Yeah, i'm wondering if I should start searching for a few more 60 springs
I used 60 rears in the front as well. Used the same spring hangers from Ruffstuff except I flipped them around. SOA and shackle reversed. Saginaw swap as well with 4x4 labs high steer. I used the ruffstuff spring perches with the three different spring pin options. Wheel base is around 104-105 with axles all the way forward/rearward on the perches.
Yeah, not too bad for a harbor freight grinder and a ready welder out in the condo parking lot.
Hangers are offset like stock. I believe the width was 38.5"? I just measured the width of the spring perches on my old SOA rear axle and kept everything the same. I supported the front spring hangers with a couple gussets but I don't have any pictures yet. Let me know if you want any more specific pics.
I wanna see/ hear MORE on these pics...
Did you add that extended plate on the hanger? I dont recall having that with the kit that I got from Dan...
So you kept the rear spring hanger in the stock location, but the bracket move the whole shootin match BACK 2 in? If so, that is good news for me!
How thick of material did you use for the shackles?
Yes, extended plate was on the hanger. The hangers were too outboarded on the frame not to. I also gusseted the hangers.
Hanger is a bit back from stock, but not much. And yes, Dan's hangers are angled such that I gained a bit of wheelbase compared to just moving the stock hangers back.
Shackles are 2x3/8" bar stock. I bought like 6' so I will be able to make shackles for days.....and it was only like 20 bucks. Here are a bunch of pics.....
How long did you make those shackles?
and is there an optimum shackle angle?
Thanks,
Tom
