60 Axels under 40 Configuration Help?
Hi,
I am new to this forum. I have 2 cruisers, both my grandfather bought in 72. One is a 71 and the other is a 72. The 72, me and my father restored in 2003 and is now my DD. For the other cruiser it is my trail rig which is my never ending project. I am new to this 60 axels under a 40 but im taking interest in it. I am running SOA front and 4 link coil spring in back which i ordered from "Proffitts", front and rear arbs, sag steering, sm420, shackle reversal, and disc brakes with stock f engine. Now im wondering, if i go with 60 axels, will i have to change everything (other than the springs), Or can this be done with not too much hassel, and what will i need other than a welder (can i stay with my spring setup now.) Like i said i'm clueless when it comes to this conversion.
I have looked at your technical links and faq (i have read around and seen that "poser" is big into that:cheers: ), but couldn't find out what i have been looking for. Maybe you guys can give me a hand?
Thanks,
Eric
from South Dakota
"should" be relatively easy...IIRC, Proffit's makes a outboard kit for the front springs, which is helpful, since the PS perch in stock spring location wants to be on top of the 60-series axles versus to the side like the 40-series housing.
rear is simple, relatively...
search "outboard springs" and you might find some info...
oh yeah - welcome :D
The work is all in the front. You will hve to outboard the spring hangers and shackle hangers by just over 1 1/2 inches on each side. Then reweld the perches on the top of the axle, and do a cut and turn. Out back, you'll need to weld on the links in the right place.
Look for dieselcruiserhead's post on putting 60 axles under a 55. It's the same difference for you.
