6 to 5 bolt..
I never knew why either. I am indifferent to either 5 or 6 bolt but would lean more towards the 6 bolt only because of the wheel selection. When Toyota went to 5 bolts, they also went from 12mm to 14mm bolts and to a larger bolt circle. Which is stronger? I dunno.
But take note, the new Tundra, 105 series and late 70 series all have the same 5x150 bolt pattern.
Some time ago there was a technical discussion about this. Toyota determined that going from 12 mm to 14mm and reducing from 6 to 5 bolts, including increasing the bolt pattern, increased strength while it reduced costs.. The calculation resulted in a 14% strength increase IIRC...
I have noticed that on alot of HD trucks, dodge etc... are going to 5 lug with a larger lug diameter, I guess that is the way to go unless it is chevy who does 8 on their HD trucks
I remember reading somewhere that it had something to do with the brakes on 79? series. that may have been BS, but at the time I remember thinking it made sense. I can't remember more on it. But I hate having and odd ball bolt pattern. Prior to this if I was on a group trip we could make a 40/60/80 spare work in a pinch. Now there isn't a chance.
