5x150 hubs on a trailer
Houston, Texas
I have a set of front wheel hubs from my 100 that I just had a Solid Axle Swap. I was wondering if I could some how use the hubs on my 3500lb axle to change the 6 lug bolt pattern to the 5x150 that I have on my 100. I cant tell right now since I wont get my 100 hubs until mid march when I pick up my 100 from Slee.
Hi,
Did you figure out a solution to this? I too would like to have the 5 bolt pattern on my trailer (3500 lbs axle) and do have the hubs from my old 99 LC. Have been trying to locate some trailer hubs online but haven't found one so far.
Assuming that these aren't unit bearings (NO familiarity with 100 series parts) the way to do this is to look up the OD of the two bearing races in hubs and the ID of the bearings used on the prospective axle. Then go find a friendly counter person at a bearing house and see if there are bearings made with those two diameters.
