5 Speed Tranny Question
David70FJ40
Older Than Most
High Point, NC
Yesterday I was driving the 40 to a meet-up with other club members when I noticed how much heat was soming from the tranny tunnel cover. I touched the rubber boot and it was very hot and when I pushed in on the boot the upper portion of the cover felt like it could have bee hot enough to burn skin. I have a minor seepage from the SC fill and can't see any from the tranny itself. Is this heat normal or do I have other problems?
In my experience, that is probably heat soak from your engine. Check your ignition timing, and your advance mechanism (if you have one). Also, do you have headers, or are you still running the stock exhaust manifold? Headers will dump a ton of heat into the engine bay, firewall, and floorboards.
F engine with a 2F flywheel for the 5 speed. Headers. The temp from the top of the tranny cover was concerning, the top felt very hot through the rubber boot.
