4WD Shift Rod Seal (Manual vs. Electric/Vacuum)
fullthrottle
New Zealand
So looking through the manual for re-assembling the transfer case... When it comes to putting the Transfer Vacuum Actuator back on, there is a seal mentioned in the diagram to be replaced. Now when I pulled mine apart, it didn't have this seal. So I thought it was either missing, or not required.
Anyway, I just wanted to check....
It seems to be that the seal is only required for the manual/stick shift 2WD/4WD selection. Not required for vacuum operated 2WD/4WD shifting.
So would mean that the oil in the transfer case would also flow through into the diaphragm cylinder body for lubrication...
Below is a pic from the manual showing the oil seal. And another pic of someone else's transfer seal from a manual/stick shift 2WD/4WD selection.
Not missing. You are correct, that seal is not present with the vacuum shift diaphragm. There is a gasket in place: 36164-60040
