4WD question
Seattle
Well i have a unusual question. I recently had my radiator and one 02 sensor replaced (bank 1 sensor 1). Now we've had snow in my area for the last week or so. Prior to having the work done my cruiser performed beautifully in the snow. Since then it feels like a 2WD car, slips and slides all over the place, and gets stuck in deeper snow it would have easily gone through prior to the work. I've been able to get through a bit easier using the power button. A couple of notes: I've been driving the car with transfer case in neutral, prior to the work i tried taking off with the 2nd button engaged and had similar difficulties, i have difficulty consistently geting the 2nd button to engage (dash light), there is now a occasional bit of sluggishness when accelerating from a stop (though not constant). Should i reset the computer? Any thoughts?
Thanks, and Merry Christmas!
Drive with the transfer case in H.
Keep the PWR button pushed all of the time.
The truck will not perform correctly with the transfer case in N
More like, the truck won't move under it's own power with the T-Case in N or Neutral....
It's been in neutral the entire time i've owned it as far as i know and driven just fine. Isn't there a fairly low top speed limit with high engaged? The question is why with the same settings is the car not performing well now when it was before.
It can't be in Neutral or else it wont move. In fact I sometimes keep the transfer case in N when I am in sketchy areas because many thieves may not think to look at that.
I would hope so. But check just to make sure. You mentioned slipping, have checked the transmission fluid?
okay ive checked it and ran through the range, i didn't realise the default positions high. As a side questioon does the diff lock switch i've read about allow you to lock the diff in high? And would that be useful in snow?
The land cruiser you have is all time 4 wheel drive, meaning that any time you drive it normally it is in "H''. "L" is reserved for sloppy stuff. If you have a center diff lock button it can be activated in "H" but again only for sloppy stuff. it automatically comes on when you put it in "L", or it should anyway. if the transfer case is in "N" it wont move.
sounds like the 2nd gear take off is still selected and the indicator is not lit? not an option in my '93 so I have no first hand experience, but your timeline and symptoms give me that hunch. What tires are you running and how worn are they?
and the other guys are right, neutral should give you an indication on the dash and zero go in any gear; for towing I think...
welcome to the MUD btw, :flipoff2: yet another example of how small and friendly the world really is.
Assuming you are in Seattle, I'll be over in Kirkland later tomorrow and possibly Saturday. If you want to meet up and ask questions, compare workings of LC's let me know.
Thanks for all the help guys. I think the 2nd engaged may be the case, light only seems to work intermittenly. Tires are bridgestone revo's (95%), really a great all around tire imo. I understand the 4wd system now, sounds like the center diff switch is a worthwhile investment. Gbell im near kirkland, i'll shoot you a message.
