4WD motor
Near Boston
So I sucessfully put the transfercase back together, was a bit harder than expected!
I'm down to the 4WD motor, the FSM says to install in a lock condition, I'm not sure where it was when I took it apart, but at this point I can move the shift fork by hand. Any help here would be great!
Not sure how this set up works?
If I engage the front lock (fork #2) is this what I'm trying to accomplish?
I did this just a few days ago. It is not hard, you just need to have both the center diff in the locked position on the transfer case and the actuator in the locked position while installing.
To lock the center diff in the transfer case you put the gear in the top and spin it by hand (counter clockwise IIRC) into the locked position. Mine clicked into the locked position which made it easy to tell that it was locked. You could take an ohm meter and check the resistance on the center diff lock sensor to be sure that it is locked (you should see less than .1 ohm of resistance when locked).
Once you are sure that the diff is locked, you plug your actuator into the vehicle and turn it to the locked position. I would have somebody watch while you engage the actuator, just to make sure that it is spinning. Once you are sure that it is in the locked position you can disconnect the cable from the vehicle and bolt it up to the transfer case.
I hope this helps.
Well the this does help! The vehicle is completely torn down for a motor swap, it has no power, and will not see life for awile longer.
I have the sensor out, so I can see it's locked, now on to the motor.
Any way to power the motor on the bench off a battery?
Here is a quote from Tools R Us:
"The slip switch on the top of the gear "times" the motor, only allows it to run in the needed travel. The only ways I see of it running outside of the allowed range, is outside supplied power or a problem in the control box. Have seen a couple jammed like that from attempting to run the motor with a battery or outside power, bad idea."
You could take the big cap off of the actuator and look at the gear inside. I am not sure what orientation the gear should be in for unlocked, but I am sure that Tools R Us would tell you if you sent him a PM.
After a Talking to Tools R Us, he explained it in basic terms form on how it works.
So after thinking all day, I remembered I used the battery charger to close the windows after I pulled the engine. So I tried it again for the 4WD motor, it worked!
Thanks All
I am glad that you got it figured out. Would you post up how he explained it please? I am interested in how you turned it with an external power source and it might help somebody in the future having this problem.
My external power supply was my battery charger, but I plugged the motor and harness back into my vehicle. Sorry for the confusion!
Quote from Tools R Us
"I'm guessing you are talking about the CDL actuator? If so, they need to be installed locked because; the mechanism is spring loaded when unlocked, not when locked. The correct way to do it is to lock it before taking it apart.
The timing between the actuator and shift fork is critical for proper operation. There is a set of sliding switches in the actuator that control it's travel, so could take it apart and attempt to line those up, and/or using an ohm meter, move the motor until the lock switch opens. This is what I do when rebuilding them, but it's not that accurate, so always run it on the truck to confirm that it's in the proper locked configuration.
Bottom line, I would use the truck to get it right, if the truck isn't available would wait to install until it is, or plug it into another truck, before instilling it."
There is more info on how they work near the end of this thread: https://forum.ih8mud.com/threads/cdl-actuator-fun.68015
