4speed
The L43 (4speed tranny) is shorter then the later model W and G trannys so you would have to do drive shaft work to put it in a 4runner. Plus you would be down grading in trannys. The earlier trannys have weaker bearings that are more prone to failure. Anything from 84-95 22r/e with a top shifting t-case will be bolt in. If you dont care about cutting the floor a very little bit then anything from 84-95 22r/e will work.
thanks man i was unsure:D
