4runner front brakes
on the north side of town
does anyone know if 1996 to 2002 4runner brakes work with a standard mini disc swap onto a fj40 axle? i have read that the earlier model 4runner calipers work, but how about the later ones? will they have a larger piston size? i want to get the largest pistons possible along with a proportioner to combat the brake bias issue when using gm rear discs while still using the later 40 rotors. in a nutshell, are the dual 40mm pistons on the 92 4runner caliper as good as it gets?
thanks all!
For toyota, that is as good as it gets. I am unsure what year the calipers changed, but I do have a pair from a 1996 T100. The only difference being the heat sinks are smaller where rim interference occurs, as compared to earlier "V6" calipers.
thanks dgangle, that article is what i'm basing the majority of my research on so far. i have heard that there is a difference between v6 and 4 cyl. calipers as well, but i don't yet know what that is. the pad part #s are different i think.
snail wagen, are you saying that the t100 calipers have more wheel clearance but the same piston?
thanks all
thats apparently what you are saying
thanks all
A four cylinder Mini/4Runner will have the small and large piston combination.
A V6 Mini/4Runner will have the four equal sized pistons in the caliper.
This is true until 1991 when they standardized the calipers, from what I have been told.
poser, to you knowledge, the standardized 91 and up calipers are for fitment purposes the same as the early v6 calipers?
thanks for all the help,
i'm gonna check pad and caliper part numbers to see if they are close.
I went to schucks to look at the 91 and earlier and the 91 and later calipers in person. 91 and later have larger than 40 mm pistons as far as i can tell, look like about 42mm. Also, the 91 and later has about 3/16 more room for rotor width but with the same backspacing as the earlier version. I think I'm going for the later ones.:beer:
