Has anyone tryed to do a 5.3l vortec swap with a 4l65e transmission? The information that I have found is that the 4l65e transmission is stronger than the 4l60e transmission. Also that the only difference in these two transmissions is on the inside. Could you use the 4l60e aa kit with the stock transfer case if the outside dimensions are the same? Information I found
http://www.fastfieros.com/tech/4l60_4l65e.htm
Any ideas or coments will be appreciated.
