4L60E leaking into transfer case help
Lancaster, CA
Hi everyone,
With a 5.3 and 4L60E swap has anyone experienced tranny fluid leaking into the t-case? The check engine light will come on and I'm getting a tranny code which means the fluid level is low. I've put more fluid in a couple of times and it clears up. But, I drained the tcase and a lot of it looked red which tells me that is where the tranny fluid is going. Has anyone had this happen and what did you do to remedy it?
thanx
Craig
I read on one of the post by @NCFJ where he states that you need to use sealant in between the TC and Advance Adapter... right where the spud shaft is in the adapter....
I know I book mark it, but cant seem to find it....sorry
I have some seepage, but not enough to warrant taking the unit apart and sealing it properly....
Ok, thanx
