4L60E leaking into t-case
Lancaster, CA
Hey everyone,
I have a 5.3 with a 4L60E hooked up to an AA adapter and stock t-case. It seems I'm getting tranny fluid leaking into the t-case which in turn is leaking through the e-brake. Anyone else come across this issue, and if so what was the remedy?
thanx
Craig
The typical fix is to install the t-case input seal backwards.
^^^yes^^^, open side of the oil seal should face the tranny fluid. Also, where front nose of transfer-case input gear presses into the front transfer-case bearing put a line/circle of silicone glue to prevent tranny fluid from seeping down into the splined between input gear and input shaft, thus working it's way directly into the transfer-case.
Ok, I'll give that a try. I've also read where others have used a speedi sleeve on the parking brake? Should I do that as well as turn the input seal backwards?
Auto tranny fluid passes through the transfer-case input bearing (even if it's a sealed bearing), then it wants to work it's way past the input oil seal and over the outside diameter of the input gear "AND" down into the splines between input gear and input shaft. The more wear there is between these splines, the worse the seepage. Soooooo my comment on using a circle of silicone glue (applied on very clean/dry surface) is just as important as reversing the oil seal.
