4l60e adapter
Anacortes washington
Hey guys happy Saturday, so I couldn't leave well enough alone and be happy with my lt1 4l60e set up. And picked up a low mile LS1 4l60e setup, figuring my adapter for the transfer case would be the same for the newer transsmision, not. So I'm looking to see if anyone might have a 6 bolt adaptor for a 4l60e. To Toyota transfer case. Or an adapter plate to go from the 4bolt to 6bolt tailhousing settup
Yes, I know that advance adapters has a kit. I'm a little shy of the 800.00 that they want for it due to having two sets of engines and transmissions for one piggie now. I do have the lt1 and 4l60e up for sale, but locally
It's the output side, the older tranni is a 4 bolt flange, which is what I have for an adapter, the newer tranni is a 6 bolt flange. I found an adapter to adapt my older tranni to the LS. I really wanted to use the newer tranni, it only has 10k miles on it, oh well
Could you use this? (Assuming output shaft length can be cut to correct length on newer trans)
Advance adapters 50-0405E
