getting ready to put things together, couple of questions. now that the output shaft on the 465 is shorter and does not go all the way thru to the other side of the stock 3 speed transfer case whats making sure everything lines up ? the bolts from the transfer case into the adapter ? also there is alittle back lash when i put the transfer case gear on the 465 output shaft its very slight but it does move alittle. when bolting the transfer case to the adapter plate should i use the gasket or silicone ? THE BIG ONE anyone know where else i can get the pilot bearing or bushing treeroot calls for because i called the company he used and they informed me they dont carry it anymore and i cant find it out here and if someone has a few let me know save me making a bushing . have a good one THANKS
