4500-5000 lbs towing!?!
Sacramento, CA
Just bought a 23 foot striper boat, weighing in at around 4500-5000 lbs. I have about 3 inches of lift in the back and was wonndering if i could put air bags back there. any comments are appreciated.
well, I would think that how much you'd want airbags would depend on the tongue weight more than the overall weight. But yes, you can put airbags in, that's what they are mostly intended for.
But it isn't going to be moving that fast uphill with 5000 lbs back there...
Dont know the load capacity of those skyjacker springs. I have OME J springs, which are heavy load springs and my truck only slightly sags with my $5,000 + catering trailer behind it. I have heard that the Skyjacker are softer than OME, so you might need bags.... the truck will pull it, albeit slowly compared to a 100 series, but who is speeding towing trailers anyway:confused:
Hope that helps,
Joel
If you're concerned about tongue weight, a weight transfer hitch would be a better option.
-Spike
I installed bags for some customers who town trailers in the past but all of them had OEM coils meaning zero lifting.
Bags usually were used to level the 80 when the trailer had a high tongue weight and as I recall they were rated for up to 1000 lbs aditional total rear cargo weight. Of course 1000 lb tongue weight is way too much to handle for the cruiser.
IMHO I don't think bags are a good idea on a 3" lifted cruiser, and by the way left and right bag should be isolated between them, meaning separated filling/relieving valve and / or compressor.
First measure the tongue weight and post it and let's see what we can figure !!!!
I have Poly Air Bags in the back springs - My 80 is stock as in zero lift.
They are excellent for keeping the vehicle level when towing with a fair bit of tongue weight - I use it when I tow a 2.5T boat Trailer...
They are only pumped up when I am towing. When I drop the trailer off the truck, they get let down again...
In saying that - I don't think they would suit a truck with a 3" Lift... but I could be wrong...
A stabaliser bar setup does a different thing - it makes the trailer chassis and the car chassis one big chassis effectively - ie. distrubutes the weight accross both the tow vehicle and the trailer.
All the airbags do is keep the vehicle level and allow you to ensure the tongue is at the right hieght for effective braking to avoid "The tail wagging the dog" and obviously reduce the chances of the springs wearing out faster.
