Need some help-
Climate control issues with an 97 40th. I have had a 94 and 96 and never an issue.
Replaced the climate control unit from a 96, flipped it to A from M, cleaned the board under the steering wheel. Had a little rust, from water. Read the FAQ's some work when cleaned others replace the part.
Issues:
Low and High work on the Fan (Not the other speeds)
Fresh Air vent does not work on auto (*flipped the switch on the back of the control unit, to M) ((It smoked, flipped back to A))
Cool/Hot cable adjustment (Temp/Heater Valve on Firewall moves fine, unhooked the cable and moving manually)
AC works on L/H
Vents change when selected, floor, defrost, etc.
Rear Heat works fine
Need some Jedi skills to help....
Issues:
AC works on L/H
