40th Anniversary Edition — wheels
Overland Park, Kansas
Hi all,
First time poster. Just bought my 1997 LandCruiser with lockers. Overall it has good bones, but a little rust to address. By far, the worst part of the vehicle is the rims which are pretty rough. 1. Can these be restored? I’m guessing no. 2. If not, leads on some new/salvage/refurbished ones? 3. Thoughts on those center caps? I believe they should be the Antique Sage Pearl of the vehicle, or some gray/silver color, but on some Land Cruisers I’ve seen black. I’d like to be as true to the original for appearance sake, as possible.
Thanks!
Tim
I would use a wire wheel on those and then paint them. The integrity looks good so I'd go that route.
Thanks! Thoughts on the caps? They are in good condition as well, and I thought if I taped off the Toyota logo, I’d paint, but not sure the correct color.
Plenty of wheel repair/refinishing in any major city. Figure $100-150 per wheel.
Or find a media blaster, have them stripped and paint yourself. You will lose the machined finish on the spokes but you can do a polished finish instead. Powder coat clear is the best option, the parts-store aerosol "wheel clear" is not that long lasting and results in a yellow hue.
GM BGM0344 (previously DSGM344) is the closest match to the Toyota gray used between the spokes.
Dupli-color FB108 is a good match for the silver used on the caps.
All 40th ed. and Collectors ed. used standard '95-'97 center caps with the gold emblems. I chose to give mine a '93-'94 (black center with gold emblem) type look with the above listed GM color. I just never got around to tracing the emblems in black.
Chrome lug nuts help it all pop. ;)
full
full
Thanks Bear80. I hadn’t thought about going two-tone like that. That looks great! I appreciate the paint code tips. I had thought about trying to do a color match from a paint chip I pulled off. Thanks again!
Mine were almost about as bad as that. Had them bead blasted and then powder coated an Audi silver. They looked about a 1000 times better after that for about $300 which I thought was pretty decent.
Many ways to go, depends on your budget and timeline.
Thanks! I’m leaning towards that. Got time on my side, although it’s hard to be patient!
full
Gorgeous truck!
Welcome @Jax05 ! I used Eagle Auto Stripping, 7000 Kaw Drive, Kansas City, KS 66111, 913-334-6331 and they blasted my wheels on ALL sides for $40 each (Cash) (Credit is $50/wheel)
I am planning on polishing mine to a "mirror" finish, but have not taken the time to do it yet.
I believe the Anniversary edition wheels are two-tone with the fronts being plain matte silver (with clear coat) and the holes being a darker color (like the graphite wheel gray) with clear coat. The center caps can be hand-sanded, then painted silver to match the wheels and have a gold paint inlay into the Toyota emblem, then all clear-coated.
Come visit us at the local club and events! Se below to see what we are up to:
KS/MO- Tornado Alley Cruisers
PM me where you are and I'll do the same. Quite a number of us are active in this area with parts and work and help.
Thanks, BILT4ME! I appreciate the heads up on Eagle Auto Stripping. I'll check them out. You're right. The rims are two-tone, with the holes being close to the trim color. Also, thanks for the tips on the center caps. While I may do a few upgrades to the vehicle, my intention (at least early on in owning it) is to be true to the original vehicle. Maybe upgrade to LED's and I may have to go to a touch screen sometime down the road. I'll send you a private message shortly...
Thanks again!
Mine were really bad. A local powder coating wheel specialist charged $60 per wheel, $300 for the set of five. The blasted them, sanded the roughest parts, and coated them in Galaxy Grey III because it was a very good match to the door trim on my '97 Collectors Edition. I was amazed at how well they turned out and would absolutely recommend this approach.
Great info, cbpeck. I appreciate the color tip! Thanks!
