Before you want to kill me and tell me to do a search because there is plenty of information out there just hear me out. I have searched and searched and read all the info. I've changed the Output Seal. Replaced with a Toyota OEM Part. I've actually bought a Speedi Sleeve twice now just to make sure there were absolutely no imperfections on the drum just to be sure. I made sure to grease the inside of the seal. I didn't put silicone behind the main nut washer only because it isn't leaking because of seepage.
The leak is extremely small and slow and just leaks down the E Brake Plate and then obviously out and it gets a very small amount of gear oil pooling and about to drip off. I know this is very minimal and its not even close to a need to add more gear oil at any point. I just want the leak to be zero. Anybody have any input here or a trick of their own?
