40 frame repair
merville, bc
i'm looking for info welding in the last foot of my frame with new c channel and replacing the rear crossmember with a new piece of c channel. also wondering what the purpose of the diagonal sections are that go from the frame to the crossmember? are they only there to support a hitch or do they strengthen the frame in a twist?
any and all info appreciated,
chris
frame
check the faq lots of info there.those braces need to be there unless you dont ever get stuck or tow someone else out.
I replaced the last 18 inches of my frame with sections from a good frame. This included the rear spring hanger. Also installed new diagonals which I bought off Ebay. Made diagonal cut of frame , match cut new frame, weld together then weld football shaped plate over splice. Do one side at a time. Drilling out rivets is a PITA. Replace rivets with grade 8 bolts.
very cool links, hadn't thought to check ebay yet. i was a little put off by the prices on cruiser solutions-it was gonna be over 1 grand. the ebay prices are definitely better. i'm probably going to look into getting the c channel and cutting myself. i do pull with this truck but had wondered if a nice thick section across the rear needed any more bracing. are people bolting in or welding in? welding seems so much stronger?
I had a local steel fabber bend up some 3/16" plate for the rear of my frame when I cut & rotated it up some for added ground clearance. I used true 4" steel channel for the crossmember & butt welded that to the new frame ends. I also added an 1 3/4" brace from the tubular crossmember to the channel & 2 braces from the tubular crossmember to the inner frame sides (for the shock mounts):
vt , thanks for the link, that's what i want to do. did you use square channel for strength or because that was what you had? do you know what size and gauge(?) you used? do the spring eyes line up with the frame or did you use a plate?
Thanks for the compliment :clap:
For my '73 40, there's a coil/ radius arm setup in front. I refabbed everything from the original coil design I already performed due to a new hybrid LC center/ D60 outer front axle. I haven't tested the new design due to waiting on a few items to finish up - custom inner axleshafts, Staun beadlocks & a few hydro hoses. The old design was flawless on the highway & trail. I was super pleased :bounce2: There are a few pics in my build thread.
